So I have a problem when after 2-20 minutes of gaming (full gpu load) the pc will completely freeze with the last frame displayed.(requires reboot) sometimes it will also hang on boot.
PC:
FX6300
Biostar TA970
Cx750m psu
Kingston 32gb ram 4 stick
850 evo 250gb (OS)
Seagate 3tb (slave)
Kingston 120gb
Crucial 120gb
GTX 980ti evga sc+
Windows 8.1 (fully updated)
Latest gpu driver
So what I've done to combat this is:
-I've moved all important files from all internal drives to a backup
-fully wiped drives clean
-re installed os (not refresh)
-ddu graphics drivers 3 times before os reset and once after.( before it didn't help)
-On new os installed Furmark and and steam.
Ran furmark= great fps 130+ 8xmsaa
installed pubg and steam installed directX for game.
Shity fps after in furmark 23-30 fps 5~10 min of gpu load back to where we started.
Also tested components in a win 10 pc. Ran fine no problems.
Problem seems to lie with steam direct x files. But it seems to affect the whole pc.
I tried this in the graphics card category with no luck. So I'm looking for some answers; anything would be appreciated.
https://linustechtips.com/topic/803528-complete-system-freeze/
8 minutes ago, BigGrease said:
When u install Windows doesn't it install its own directX files...?
And steam associates the files by ltself.
Yes it does but the drivers do too.
7 minutes ago, Bartb56 said:
i'm not sure about that i always download them and install them myself same with drivers
You don't have to it's included.
2 minutes ago, Bartb56 said:
nvm you're right directx does install with windows,
did you check the temps of your cpu/gpu when your pc reboots?
could be a power does your psu give enough watt?
750W is more than enough for FX 6300 and 980TI. And it's good quality.
What temps?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/803528-complete-system-freeze/#findComment-10100815
What temps?
One thing I should say is that when the pc was reinstalled furmark at 130fps ran the gpu at 79° 50% fan and before on old system it would run 84° 100% and crash. It's now crashing again but its not running as hot ?????
https://linustechtips.com/topic/803528-complete-system-freeze/#findComment-10100846
Can you reinstall Windows?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/803528-complete-system-freeze/#findComment-10100850
I can as the pc is fully clean. But why when I have just installed it like a week ago fully clean and everything? U think it might be a bug with the installed v.?
It had the base version of Windows 8.1 Installed with steam and crashed. Fully updated 8.1 to latest and still crashing
https://linustechtips.com/topic/803528-complete-system-freeze/#findComment-10100868
Does it only crash under load or totally random? Have you tried with different RAM or GPU? I would vouch for hardware issue more than software/drives. Symptoms would have matches bad HDD, and could even be that. But they could as well be almost any other hardware part.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/803528-complete-system-freeze/#findComment-10101140
Then how do you explain why the pc only crashes once steam installed it's own directX files for a certain game.
https://linustechtips.com/topic/803528-complete-system-freeze/#findComment-10102030
Thats why I asked if there is pattern or if its random. You were talking about temps earlier and before that had wall of text where you say you've installed multiple times. DirectX is just software library. At most it could have issues with GPU -> test with another card to see if thats issue.
https://linustechtips.com/topic/803528-complete-system-freeze/#findComment-10102051
