My computer will start but it will not post and since toms hardware is a bit tricky to navigate on my phone I chose this as away to get help
Specs:
Cpu and fx 8370
Ram 12gb 1333 asteck
Gc: RX 470 4 Gb
Cup cooler : corsair H60
Mobo: gigabyte 78LMT-usb3
Please help. Againbit will turn on but will not post
https://linustechtips.com/topic/803418-i-need-help/
did you just get it
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/803418-i-need-help/#findComment-10099652
PSU model?
Don't use the cpu cooler to cool down your drinks!!
Make sure all the cables, especially the 8pin CPU power cable, are fitted in properly.
Desktop benching:
https://linustechtips.com/topic/803418-i-need-help/#findComment-10099653
