Hello, i am having a problem with my new 'rig' it came in today and i started building it but the problem now is that i when the pc starts it just sits there not doing anything and the cpu led is constantly on but when i reset the bios using the jumper and start the pc there is no led and the cpu fan i quite i have tried reseating the ram, cpu, gpu, every cable even but nothing solves my problem (yes iam aware that ryzen first boot takes a while but it doesnt take an hour)
parts:
Msi b350 Tomahawk
ryzen 7 1700
G.skill trident z rgb 3000mhz
msi rx 480 gaming x
nzxt h440 hyperbeast
corsair cx550m
Red ​White ​Blue
https://linustechtips.com/topic/803198-ryzen-7-1700-not-posting/
parts:
Msi b350 Tomahawk
ryzen 7 1700
msi rx 480 gaming x
corsair cx550m
if you are plugged into the hdmi, it wont post since there are no drivers. VGA to HDMI, or DVI (in my case) to hdmi cables worked for me so then i could get the drivers to use the HDMI
what do you mean?
i have a gpu and cant even get into windows
Red ​White ​Blue
3 minutes ago, Abyss Gaming said:
Sure the HDMI is plugged into gpu and not Mobo?
okay the pc is now turned on and has no red led indicating that the ram or cpu is dead but it stil doesnt dislay anything even with a diffrent gpu
Red ​White ​Blue
Just now, Abyss Gaming said:
Now that the light is off if you wait a while will it boot since ryzen first boot? Try different outlet.
i have it rumbling next to me but also worth mentioning is that the cpu and gpu dont heat up at al
Red ​White ​Blue
give it a bit.
the first boost takes a while. sometimes over a minute.
try only one RAM stick also.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
3 minutes ago, Seabosz said:
nothing absolutly nothing
well you might have a dead component if nothing else works unfortunately.
Laptop:
Just now, bcguru9384 said:
is cpu installed correctly???
linus has video on cpu installs
arrow on cpu to the beveled slot corner i believe is what was said
yes the socket on this mobo even has the socket turned 90 degrees i checked but i think iam going to rma the stuff
Red ​White ​Blue
