3 minutes ago, DrMikeNZ said:
Usually 90 seconds is sufficient, but there is no harm in waiting a little longer and 5-10 minutes is a perfect excuse to have a coffee break.
Yeap, comes in handy when I have to do that at school, gets me out of doing the work xD.
Have you tried turning it off and on again?
https://linustechtips.com/topic/803028-weird-problem/#findComment-10095167
Had you overclocked the CPU ?
Ryzen 5 1600 Stock
Gainward GTX 1060 Stock
ASUS Prime B350 Plus
8 GB DDR4 2133 MHz Gskill
Be Quiet! 400 Watt unit
Corsair Carbite SPEC 03
My Old shitty System :
Intel Core I3 530 4x 2,93 GHz
NVIDIA GeFroce GT 330 750 MB VRAM
4 GB (2x2) Samsung DDR3
Sorry for my English. I'm from Germany !
https://linustechtips.com/topic/803028-weird-problem/#findComment-10095206
Yes, it's overclocked. But it worked normal 6 months. I think overclocking has nothing with this. And temperatures are fine. If I remove cmos I will lose all overclocking settings in bios but I will try.
I have 970 pro gaming aura motherboard and fx8300
edit: removing cmos battery didn't work
https://linustechtips.com/topic/803028-weird-problem/#findComment-10095279
