I dont know if this is the right section.
I had one 700 APC UPS for about a year but then i needed another one for another pc right?
So i bought the same UPS but from a different retailer.
I works fine but after some time of using it you PC shuts off and the UPS starts beeping. Yes it is plugged in and it is charging.
https://linustechtips.com/topic/802660-ups-problems/
ok so the battery backup in the ups is not kicking in for some reason. Some ups have a "reset" feature, try doing a couple of those resets and see if the problem persists.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/802660-ups-problems/#findComment-10091681
try disconnecting stuff from the battery backup. Your psu might be getting overloaded and shutting down to protect itself.
Also, if your pc is drawing too much power( above 700va), it will shut down the ups no matter what.
https://linustechtips.com/topic/802660-ups-problems/#findComment-10091732
It only has PC connected and its an old Dell office PC.
https://linustechtips.com/topic/802660-ups-problems/#findComment-10091740
how old? full optiplex dells with crt monitors can draw more than 500w easily. your ups is rated up to 420w
https://linustechtips.com/topic/802660-ups-problems/#findComment-10091767
in that case your ups might be faulty
https://linustechtips.com/topic/802660-ups-problems/#findComment-10091872
