Hi there so i copied(for studying purpose) a complete folder of installed software on a server.
the software is called ez-link it is a net cafe timer software. I'm just searching for the configuration of this software (I know this one has sql database) because the account is online and connected to each branch so must have database.
I know much of settings would be in a .conf file but any other setting or can give me any clue where to find to? thank you
https://linustechtips.com/topic/802446-help-looking-for-configuration/
31 minutes ago, Dat Guy said:
I'm actually unsure how this is related to programming.
Doesn't that software have a manual or something?
I'm sorry i was confuse if i will put it on programming or software but since i am looking at its program files i though would be fit for this section
