https://www.logitech.com/en-ca/headsets
Think I'm going to buy the h151 or the h110 or the h111
Posting again for last chance for me to get feedback.
I need to hear my speakers well while having this on. Will only be used for communication. I don't care about sound quality so long as the perosn I'm hearing is intelligible to me. All else is durability/warranty and low price.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/802306-audio/
If you're planning to have this on with your speakers on (assuming the headset will be used as a microphone as well), you will be giving feedback of the other person through your microphone and he will hate you forever.
Current Build
Successful Builds
https://linustechtips.com/topic/802306-audio/#findComment-10087338
Actually, I've used 3 different headsets so far and they manage to not catch my keyboard or speakers! better then some people's mechanical typing sounds ;)
I'm glad either way for all involved that I can turn up my speakers without a problem.
https://linustechtips.com/topic/802306-audio/#findComment-10087348
