Right, so I was thinking about building some sort of "test PC" for under £100 in British Sterling (online) to test PC building (so I don't blow up a £500+ system) as I have never built before. I want to eventually upgrade my Q9650 core2quad and GTX 470 (<- mainly this) but with no budget atm I would only like suggestions as I dunno when I can afford. Looking for under £200 GPU and NVidia only.
Edit: this is two separate sentences, just to clear. Test Pc | Upgrade
Edited by Nath_Unknown
Not clear intention
OOo 1050ti (cries in silence) -- Nath xD
https://linustechtips.com/topic/802266-gtx-470-scrub-needs-help/
Used 750Ti 2GB, 1050 2GB or 1050Ti 4GB.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
building a pc isn't hard, ground yourself, don't jab screwdrivers into pcbs or scrape your mobo around on mobo offsets and disconnect power from the psu before poking around... if power has been connected at some point before be very careful of capacitors, maybe check a couple build guides on youtube. Just doesn't make sense to blow money like that
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
