Will these work together
Solved by 3rrant,
55 minutes ago, Swiggles said:I plan on building a pc with the asus Maximus ix formula mobo and want to run 4x16 of corsair dominator platinum se http://www.corsair.com/en-us/dominator-platinum-se-32gb-2-x-16gb-ddr4-dram-3200mhz-c14-memory-kit-blackout-cmd32gx4m2c3200c14m
the site says it's compatible with 100 series?
Be sure to activate XMP profile in the BIOS and yeah, no problem should occur.
