I'm looking into potentially using the Thermaltake X71 TG for a crazy custom loop. I know the basement can fit up to a 360(3x120) rad, as can the top. I also know that (provided you remove the optical drive bays) you can fit up to a 480(4x120) rad in the front. Has anyone tried fitting a 480 rad in the front and a 360 rad in the top at the same time?
https://linustechtips.com/topic/801641-does-it-fit/
http://www.thermaltake.com/products-model.aspx?id=C_00002998
Doesn't seem that a 360mm rad will work in the basement. You can do the 480 in the front and a 360 in the top, or side. According to the specs sheet. I see no reason it shouldn't work. But i have no experience with this case.
https://linustechtips.com/topic/801641-does-it-fit/#findComment-10080623
The "side" is in the basement.
https://linustechtips.com/topic/801641-does-it-fit/#findComment-10081902
