So i wanna purchase the Acer GN GN276HL.
I already have a monitor that uses my only HDMI-- my GTX 1060 has 3 displayport and one hdmi.
Is it possible to have a dvi (coming from the monitor) go to a displayport? I want to know if i use an adapter (dvi to displayport), will it still be able to do 144hz?
thank you.
https://linustechtips.com/topic/801515-question-on-output/
thank you.
https://linustechtips.com/main/topic/729232-guide-to-display-cables-adapters-v2/?output=DP&input=DVI
https://linustechtips.com/topic/801515-question-on-output/#findComment-10082416
