System specs? And try Windows Event Log
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/801105-fallout-4-not-starting/#findComment-10074827
Your going to need a better computer. Sorry!
https://linustechtips.com/topic/801105-fallout-4-not-starting/#findComment-10074847
If you want to do this kind of gaming, you will need at least a i5 and a GTX 1050 to get decent framerates
https://linustechtips.com/topic/801105-fallout-4-not-starting/#findComment-10074850
24 minutes ago, fidlerontheroof23 said:
I know that my PC sucks :) I'm just planning to tide myself over until I can afford a decent pc.
Yeah you can't play most games I have troubles running CS:GO on my laptop (i3-5020u 8gb of ram Intel HD 5500)
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/801105-fallout-4-not-starting/#findComment-10074955
It is likely that if you could get it running the frame rate would be unplayable.
if you are set on playing fallout, you'd be better off trying the older games (fallout 3/new vegas), but no guarantee how well they would work on that PC.
https://linustechtips.com/topic/801105-fallout-4-not-starting/#findComment-10075141
