DSL and Lubuntu Wi-Fi Help
Solved by Guest,
I ended up fixing it by as suggested, reluctantly reinstalling the OS as I must have changed something I shouldn't have.
I went with LUbuntu 16.04 as it was on the USB I picked up.
I used the following commandsin terminal from askubuntu.com after summoning the terminal with control + alt + T:
sudo -i
echo "blacklist ideapad-laptop" >> /etc/modprobe.d/blacklist.conf
modprobe -r ideapad-laptop
exit
EDIT:
if you can connect to wifi but not access the Internet - click on the wifi symbol, edit connections, select the wifi network, edit, ipv6 and change it to ignore and save.
