Budget? Might be worth going Intel instead of sticking to AMD y'know.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/800714-cpu-help/#findComment-10070683
Just now, Sebastian23 said:
Yes budget of 500 USD
A Pentium G4560 + GTX 1050Ti would be my pick.
https://linustechtips.com/topic/800714-cpu-help/#findComment-10070685
I used to be biased towards Intel, but after doing my research, Ryzen is a solid, affordable platform. They're more focused for PCs that need multiple cores for heavy work like editing, rendering etc. However, if you have a budget like that, and you mostly want to game, I'd go with a Pentium G4560 / i3-7100, paired with a GTX 1050 / GTX 1050 Ti. Not sure if you want the CPU for an upgrade or for a full build, but if it's a full build, cheap out on everything else except the PSU. I'd recommend an eVGA SuperNOVA G2 550W.
https://linustechtips.com/topic/800714-cpu-help/#findComment-10070703
  • 2 weeks later...
Thx for the advice
https://linustechtips.com/topic/800714-cpu-help/#findComment-10129606
