Hello everyone,
I've 2 issues with my system: Windows 10 resume from sleep mode is very slow. It takes almost 2 minutes until i can use windows. Has anyone an idea what could be the problem?
Second Problem: I've a a problem with a keyboard shortcut; the ''@'' symbol takes a full second to appear when i type it. It's really annoying and it's also the only keyboard shortcut that behaves like that.
Thanks in advance for your help
https://linustechtips.com/topic/800523-2-issues/
Hmm how long do you have Windows 10 installed in your PC?
                    PSU Tier List: https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
CPU Celeron n2830 - GPU Integrated - RAM 1x4GB DDR3 1333MHz - Storage 750 GB 5400RPM HDD
                                                Operating System Windows 10 Home
https://linustechtips.com/topic/800523-2-issues/#findComment-10068639
try running CCleaner.. is there anything in the taskmanager hogging resources?
Also provide your system specs please
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/800523-2-issues/#findComment-10070937
I'll try CCleaner thank you!
PC Specs
  • CPU: Intel Core i7 7700k @ 4.8 Ghz
  • CPU cooler: NZXT Kraken X62
  • Mobo: Asus Strix Z270E Gaming
  • GPU: Asus Strix GTX 1080Ti OC Edition
  • PSU: Seasonic Prime Titanium 850W
  • RAM: 32 GB Corsair Dominator Platinum @ 3000 Mhz
  • SSD: Samsung 960 Pro M.2 512 GB
  • OS: Windows 10 Pro
  • Case: Phanteks Enthoo Evolve ATX TP Edition
Periphery
  • Monitor: Asus ROG SWIFT PG27AQ
  • Keyboard: Corsair K95 RGB Platinum
  • Mouse: Logitech G502
  • Controller: Xbox Elite Wireless Controller
  • Mouse Pad: Steelseries QCK XXL
  • Mic: Samson C01U
  • Headphone: Bose QC 25
https://linustechtips.com/topic/800523-2-issues/#findComment-10072695
PC Specs
Periphery
  • Mic: Samson C01U
that's a pretty good setup, almost mirrors mine perfectly.. (check my signature)
and with a nvme drive, it's *almost* just as fast to turn the pc off completely :P
open CCleaner, run the cleaner and clean the registry too, and check the startup and scheduled task (Tools -> Startup) to see what is said to boot together with windows. if you are unsure what to disable, take a screenshot of the startup and scheduled task tabs and post them here
Personal Rig Specs
https://linustechtips.com/topic/800523-2-issues/#findComment-10072717
