First 1000$ Gaming build
Solved by The Sloth,
ryzen 1600+ used 970 or 980 i5s are not worth it anymore.
- a bit above your price range- https://pcpartpicker.com/list/wB2fLD, get windows from kinguin
- price range- https://pcpartpicker.com/list/bFQNVY
i would suggest the 1070 build, if you spend extra 52$.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals2 -
6
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards5
