Hi, my friends pc had this problem, blue screen appear and this message appear : ***STOP: 0x00000124 (0x0000000000000000, 0xFFFFFA8006B57028, 0x00000000BE000000, 0x0000000000800400)
I'd search on the web for the solution but I didn't found it... Someone said that this occur because there is problem with cpu and others say that it is because by bad hard disk, please help guys.... Everything is new in his pc except secondhand i3 2120..
His pc spec is:
Core i3 2120
4gb Elixir 1333mhz
ASRock B75m r2.0 (BIOS is up to date which is version 1.20)
500gb WD Caviar Blue 7200rpm
Sapphire HD6570 2gb DDR3
Cooler master DI5-9GDPB-0L-GP
Standard My 10's mid tower case
450watt PSU (standard psu)
Standard Samsung DVD-RW combo
thanks...
https://linustechtips.com/topic/8003-need-help/
You may need to over-volt your CPU slightly, or it could be a problematic ram module.
Stress test your CPU with P95 on blend for at least 12 hours to ensure stability. Also have a temperature monitor program when doing this to ensure that you are not overheating your CPU.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/8003-need-help/#findComment-90217
Try restoring factory defaults to the bios. If you've been messing around in there, you may have adjusted something you shouldn't have.
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
https://linustechtips.com/topic/8003-need-help/#findComment-91644
