What's your budget?  Right now, the only GPU that can consistently push high frames at 4k ultra is the 1080TI, which costs a pretty penny.
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
https://linustechtips.com/topic/800133-i-need-help/#findComment-10064698
I would recommend looking at other cases unless you already have Evolv and aren't too worried about temps. Those cases aren't very good with overall airflow. Which means your components will be bit hotter than what you see in reviews.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/800133-i-need-help/#findComment-10065348
