I started may pc up one day and i played gta 5 and i heard it cut out with the sound then went not responding and then cut in and it works but sometimes it crashes
and it started to just do it when i am not playing a game sometimes it also Just turns the sound off completly and i have to restart i use steam and windows 10
https://linustechtips.com/topic/800069-help/
first post your system specifications, without that we are just shooting blindly in the dark.
have you reinstalled drivers?
what are your temperatures during idle and load?
does the lights in your house flicker sometimes? (this indicates brownouts/dirty power)
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/800069-help/#findComment-10065612
