Hey Guys,
I bought a new keyboard recently and only just realized it has 4 different polling rate options, I've had it on the lowest the entire time. When i try bump it up the keyboard seems to reboot and i'm unable to type anything on any setting other than setting 8. 125hz instead of 1000hz. Would anyone know why this is?
Another problem, whenever i plug the second USB into my PC it instantly shuts my computer down. Is my motherboard just not compatible with this keyboard or something? My black widow ultimate works just fine.
Corsair Gaming K70 RAPIDFIRE Mechanical Gaming Keyboard - Cherry MX Speed (NOT RBG)
Specs:
64bit windows 8,1
16gb ram
Gtx 960
Asus Z78M-E motherboard
All help appreciated thanks !
https://linustechtips.com/topic/799566-corsair-k70-problem-need-help/
Ok, I am mostly clueless, but I think it may be a defective keyboard.
If you have any warranty or receipt, I would try to exchange it.
Main Laptop: Google Pixelbook
Dev mode w/ Cross Enabled
PC: Ryzen 7
1700x / 32GB 2667 / GTX 1080 / 1.5 TB of SSDs / 1TB of HDDs
Monitor: AW3418DW Ultrawide
120hz / 3440x1440 / RGB / Amazonbasics Dual Monitor Arm
2nd Monitor: Dell U2515hx
25 inches / 1440p / Portrait / Amazonbasics Dual Monitor Arm
are you using the usb ports on back of motherboard, not front usb ports? Try swapping between usb 3 and 2. The fact that your whole computer shuts down sounds like a usb short or psu issue. Try the keyboard on another computer, then contact corsair customer service imo.
Specs: Amd 1700x | NH-u12s | Asus crosshair hero vi | 2x8g Gskill flare x | Zotac 1080 | Samsung 960 EVO | Seasonic ssr-750GD | Thermaltake core x5 |
The polling rate switch is meant for older systems and stuff. So you do not need to change this setting if your computer is fairly new.
About the second usb connector,  maybe you are exceeding the number of usb devices connected. If your motherboard senses an overload, it will shut down to prevent any damage.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
