Ok so I bought a used R9 380 put it on my pc and the temps were 99ºC, I then bought a new pc case (the define S from fractal design) because maybe it could be the cooling since I had a bad case but the temps are still 99ºC, so now I don't know if the problem is still the case and should I buy more fans or is it the gpu.
So what can i do?
idk if specs are importante but:
cpu - ryzen r5 1600
gpu- r9 380
case- Define S (with default fans (2))
Motherboard- MSI b350 Tomahawk
Cooler - stock
Ram - 16GB of Vengeance lpx
Edit:
I'm currently underclocking and undervolt  it to 900Mhz and it runs at about 72ºC
Edit 2:
I will replace the thermal compound tomorrow since some of you suggested it
https://linustechtips.com/topic/799449-r9-380-overheating/
So what can i do?
cpu - ryzen r5 1600
gpu- r9 380
Cooler - stock
Edit:
Either the temp reading is bad, or the TIM is cracked, either way replace it. I have an R9 380X and even overvolted to all hell on water it never went over 60¨C
Yours faithfully
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057023
Which temperatures? CPU or GPU? MB?
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057024
Just now, tomigr said:
GPU
Is the Fan spinning ? If yes, maybe you should try to replace the thermal compound.
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057044
^ this, change the thermal paste and pads if you can.
also check of the fan(s) are ok and are turning at a good speed.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057052
I can if you tell me how I never used msi afterburner
Download the program. open it, third graph on the right is GPU Usage. Just do the old "Ctrl+Prtsc" and send the screen shot our way.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057055
One time I did get an erroneous reading of over 256°C for a second, I was like WTF then oh what the hell. The card was heavily volt modded when it happened and had a AIO on it, running close to 1210 MHz. So the temperature sensor definitely can make mistakes, however I'd say it's the thermal compound.
Yours faithfully
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057062
there's a tutorial in the forum's Tutorial section, it's old but should still be relevant ;
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057069
Here is in stock settings
That is.... very weird, I've never seen such a massive jump in temp for such a small frequency increase. What kind of cooler and model of card is it? Either way change the thermal compound, that should fix that.
Yours faithfully
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057132
Yikes! Alright then! I'll suggest what everyone else said, which is replacing the Thermal Paste. (I'd suggest Arctic MX-4)
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057135
https://www.msi.com/Graphics-card/R9-380-GAMING-2G.html#hero-overview
this one
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057137
Wow, I assumed it was a reference card, yeah the thermal paste must be bad or a heatpipe is punctured, possible multiple ones, although it should still cool. Just replace the compound and it should go down to the 50°C's at 100% fan speed.
Yours faithfully
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057144
Ok I will do that tomorrow then and report my results
https://linustechtips.com/topic/799449-r9-380-overheating/#findComment-10057156
