Sup folks,
I recently cleaned my pc of dust and when I tried to start my pc afterwards, I got no signal whatsoever, and no POST beep or error codes. Help? I've tried all troubleshooting tips in the pinned thread for this sub-forum.
System:
CPU: AMD A4-3400
GPU: ASUS GTX 560
4GB RAM
Not too sure on the mobo make and model.
Video:
Thanks in advance,
Cheers,
TJ
https://linustechtips.com/topic/799326-pc-wont-post/
Remove the GPU and try using the iGPU to POST. And if you have a different PSU, try that, as your current one looks pretty sketchy.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/799326-pc-wont-post/#findComment-10055768
Sorry to hear your troubles, how did you go about dusting the PC?
Did you use a spray can? Did you remove any components to clean behind them?
If you used a spray can, I would spray around a bit more just to make sure you haven't caused any potentially moist dust to short a circuit. I had a shorted circuit yesterday due to a Hyper 212 Evo mounting nut wearing through the coating on the board, that stopped the machine from turning on entirely - it's fine now after removing the nut, no harm done.
Taking out the GPU isn't a bad bet as Zando Bob suggested. I would re-seat all the power connectors to make sure the pins are making good contact as well. Even though it shouldn't be the cause of the problem, it doesn't hurt to spend 30 secs ensuring it isn't the issue.
Lets us know how those steps go...
https://linustechtips.com/topic/799326-pc-wont-post/#findComment-10055784
2 hours ago, manuel kruza said:
I say the PSU is fine but yes, do try use the integrated graphics
Will try that once I'm home. PSU  was included with the case (it's a Cooler Master though) and 6 years old, so might have given up the ghost. Will try using iGPU
https://linustechtips.com/topic/799326-pc-wont-post/#findComment-10056406
Will try these steps and let you know
https://linustechtips.com/topic/799326-pc-wont-post/#findComment-10056418
9 hours ago, Zando Bob said:
9 hours ago, manuel kruza said:
9 hours ago, Aloe Vera said:
Okay, really stupid and idiotic, but I've made an absolute beginner's mistake. I had taken out the CPU power connector and hadn't put it back... Really dumb, I know, but at least it's fixed.
https://linustechtips.com/topic/799326-pc-wont-post/#findComment-10058534
xDxDxD Did the same thing on my build, and I was freaking out since it wouldn't post!
Mouse: EVGA X17
https://linustechtips.com/topic/799326-pc-wont-post/#findComment-10058711
Ahh well, at least it's all fixed. It's amazing how much tension gets built when a PC won't post. I think there should be a PC building mat with a simple checklist to remind the builder what should be double checked before booting - a company should jump on that! - although it's probably already done...
Anyway, at least these threads reiterate the importance of double checking the basics before anything else.
https://linustechtips.com/topic/799326-pc-wont-post/#findComment-10060471
