https://pcpartpicker.com/list/Gq84TH
This is my build, budget not over 1.3k, I have a couple questions
1. If I stick with this build do I need to buy anything additional for my CPU cooler to hook with the mobo
2. Should I go with a 7700 (non k) over 1600 ( Planning to have this build for a long time)
3. RX480 or 1060 (both MSI gaming x to match color build)
any suggestion would help thank you
https://linustechtips.com/topic/799094-help/
Are you doing gaming or content creation?
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/799094-help/#findComment-10053317
Also, right now is a terrible time to buy gpus, I would wait.
My Rig
 Peripherals
https://linustechtips.com/topic/799094-help/#findComment-10053320
This deepcool thing is pretty much BS xD
Get an hyper 212 and a Reyzen 1700
1. -
2. definitely Ryzen more cores is a good thing for the future
3. 480 is fine for 1080 and little bit cheaper
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/799094-help/#findComment-10053322
20 minutes ago, Microsoft Master said:
Hay the E.V.G.A 1050 on amazon just dropped to $100 usd, and best buy is selling 1080 founders editions for $570
I do not like the 1050 at all but but If i'm really trying to get my PC I'll get the 1050 ti since GPU price are over the top
https://linustechtips.com/topic/799094-help/#findComment-10053443
39 minutes ago, sosatommy said:
I'm honestly just about to buy a 1060 i found for $310, do you know when this GPU craze is gonna die
I wish it would, I wanted an rx580, but cant buy it cause of these miners. These miners are screwing the prices so much.
My Rig
 Peripherals
https://linustechtips.com/topic/799094-help/#findComment-10053599
