Haven't used an AMD board in a long time and I can't help much.
Does your BIOS have an option for changing Vcore and multipliers?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10042815
It does have those options, however, this person is saying the board shouldn't be overclocked on http://www.overclockers.com/forums/showthread.php/745146-OC-with-GA-970A-DS3P
Are they right when they say 4+1 shouldn't be overclocked on?
I'm not sure if it's the same exact board, but I would assume its at least similar.
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10042822
you can oc on that board but many of the 970 chipset boards have shitty power delivery and sometimes not even a VRM heatsink which can keep the VRMs a bit cooler and help with stability
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10042853
Read up on that thread you posted. You can look into some heatsinks and thermal pads on Ebay. See how those affect your VRM temps before attempting any overclocking.
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10042857
It looks like mine does have a heat sink on the VRMS, right now the CPU is automatically overclocked to 4.1, should I check VRM temps?
How do I know if I have good power delivery?
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10042905
I believe Aida64 can check VRM temps if your board has a probe in the area.
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10042910
Yes. Do keep an eye on your temps. Don't know what the safe limit should be for AMD CPU's though.
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10042930
You'll have to check your motherboard's manual. Each manufacturer uses different values for their sensors. For mine, it is motherboard/CPU socket/chipset.
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10043103
ignore AMD temps, because the sensors are complete garbage. It uses digital temp measuring thats why for some people cpu temps are showing as 20°C when room temp is 24°C
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10043132
I once heard it was less accurate at low temps, what about high temps? I maxed mine at 58c using R15
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10043197
on some other forums like 2 years ago when i looked, some guy did temp testing with thermal couples and he said that when his fx 8350 shows 65°C his cpu is actually running at 85°C, not too big of a deal for an AMD chip doe since AMD apparently also has a higher thermal tolerance according to themselves. some r9 290x cards for example ran always between 90-95°C
https://linustechtips.com/topic/798075-need-help-overclocking/#findComment-10045485
