Hey im building this PC soon https://pcpartpicker.com/list/ZbBmzM and I need a case to go with it. (The case in the list now is just a place holder) My requests for the case are it has to be black and only black, no secondary color like the one on the build now. It also has to support an one optical drive. My budget for this case is 40$ and below. If possible (Not Needed though) find a case that comes with fans. I do not need radiator support I will be air cooling. If you need anymore information let me know. Thank you for reading.
https://linustechtips.com/topic/797765-case-help/
Try for a corsair 100R or 200R, sometimes they drop to $40ish.
https://www.reddit.com/r/buildapcsales/
also that is a reddit for sales on new hardware.
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/797765-case-help/#findComment-10040171
Ok ill will look into those cases thank you.
https://linustechtips.com/topic/797765-case-help/#findComment-10040198
https://pcpartpicker.com/list/YTnnVY this is better and quieter
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/797765-case-help/#findComment-10040475
Im on a really tight budget and that video card would put me over it I would love to get it but not enough money. Thank you for your recommendation though.
https://linustechtips.com/topic/797765-case-help/#findComment-10040524
I know but it's me and how I work I like to have cool components and I know how tight a budget can go I've spent only $375 on my PC (snow pesos) and I might have a dead mobo that I bought for retail price
https://linustechtips.com/topic/797765-case-help/#findComment-10042522
