Question about sleeving and cable position.
Solved by matt_the_d0ct0r,
If I'm understanding you correctly, you just swapped the positions of a black wire and yellow wire, then No this won't be a problem. All the wires are the same, just plain copper wire. However, MAKE SURE they are swapped on BOTH the motherboard side and the PSU side! If not you will definitely have issues. Black is usually ground and yellow is usually 12 volt. Big difference.
