I have been having a very weird problem on my computer where chrome will randomly freeze then refuse to boot up afterwards. I figured a work around by installing canary and that worked for about a month but now it won't boot up either. If somebody can figure out what is going on please let me know.
https://linustechtips.com/topic/797526-i-need-help/
1 minute ago, Brooksie359 said:
Have you tried running an Antivirus software or even a windows defender scan? You could try uninstalling chrome and reinstalling if that doesn't work.
I have tried running antivirus software and nothing has come up and I have uninstalled and reinstalled chrome at least 30 times no exaggeration
https://linustechtips.com/topic/797526-i-need-help/#findComment-10037353
Are there any plug-ins that could be causing this? I mean a last resort is a fresh install of windows.
https://linustechtips.com/topic/797526-i-need-help/#findComment-10037359
Considering I cant get it to boot I don't know
Yeah I was just wondering if maybe you had installed a plug-in recently that you remember. If you can't then I'm unsure what the issue could be. You could always do a clean install because that is what I do when I have annoying issues like that.
https://linustechtips.com/topic/797526-i-need-help/#findComment-10037432
I will keep that in mind but I haven't installed any plugins recently, thanks for the input
https://linustechtips.com/topic/797526-i-need-help/#findComment-10037453
