Hi,  I am looking for some PC components to use in a build hopefully next year, I do realize that new products are going to be available nest year but here is my list so far;
CPU Intel Core - i5 4670K Quad Core = £179.90
Graphics Card - EVGA Nvidia GeForce GTX 780 Ti =  £584.58
RAM Corsair - Dominator Platinum 16GB (2x8GB) = £172.90
Motherboard -  Asus Sabertooth Z87 £188.59
Power - Suply Corsair Gaming Series 2013 Edition GS 800W = £80.92
Cooling -  Corsair Hydro Series H100i = £83.91
Fans -  Corsair CO-9050006-WW Air Series SP120 =  £21.99 x2
Screens -  BenQ RL2455HM 24 inch =  £164.69 x3
SSD -  Samsung 840 Series 120GB =  £79.39
HDD -  Western Digital Green - 2TB  = £64.75
Case -  Corsair Obsidian Series 750D ATX Full Tower =  £155.00                         Grand Total -  £2,127.99
Tell me if there is anything that i should change.  (by the way it is a black, silver and blue color scheme)
https://linustechtips.com/topic/79735-need-help-choosing-components/
That looks like a really good build, but it's difficult to go wrong with £2000
if you wanted to save some money, then i would advise:
  1. Cheaper RAM
  2. Cheaper Cooler (Unless overclocking a lot)
  3. Maybe a cheaper Motherboard
Welcome to the forum, and enjoy your stay :)
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
  1. Cheaper RAM
Thanks I might be overclocking and I might even be getting a custom loop instead of the H100i but it all falls on the price
what are you using the pc for? gaming, editing, streaming, or all of it?
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
I wouldn't advise a custom loop
Honestly i would advise a CM Hyper 212 Evo
All of it. Hopefully
in that case change the gpu to a 780 , and get an i7 4770k , because streaming uses your cpu mostly
I could still change it to the i7 4770k and keep the 780 ti probably
ah cool ;D good choice
