I'm confused are you suggesting running only the liquid cooling system off of that PSU?  Because yes, that would be WAY more than enough.
450W should be enough
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
no, the system its self and the loop, so the gpu, cpu and loop and everything else in my pc
i will have 2 rads and a d5 pump res combo in my loop
a 650 will handle that just fine
... surprised this wasn't moved.
6 hours ago, 107x said:
for the reason of what? its a question on if i would have enough power with my liquid cooling xD
So the only thing drawing power compared to an cooled system is a pump? Still should have been in the psu section.
38 minutes ago, 107x said:
but it was directly a question about my cooling lmao give up
You didn't ask anything about cooling though.
