Chassis intruded after raid
Go to solution Solved by ARikozuM,
I would ask Asus support themselves. This is a very niche issue and isn't likely to be answered soon.
Also, have you checked the manual or BIOS for the intrusion setting?
So i just put a computer together and it posted
still no os the build is
intel 6900k
asus x99 deluxe II
samsung 960 pro
2 wd black 1tb
2 evga 1080ti
so i read online that if i wanted a raid (with the 2 wd black) i should do it before the os install, so i go into the bios and activate the raid controller
after that i just keep getting "chassis intruded" fatal error and cant do anything. Any ideas why i cant make a raid?
https://linustechtips.com/topic/796934-chassis-intruded-after-raid/
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
intel 6900k
asus x99 deluxe II
samsung 960 pro
2 wd black 1tb
2 evga 1080ti
There are usually options in the BIOS for Chassis Intrusion, if you can get into the bios it should be under security of some sort.
intel 6900k
asus x99 deluxe II
samsung 960 pro
2 wd black 1tb
2 evga 1080ti
Do you have TMP setup? Or some admin BIOS password?
so i fixed the problem, i appears the jumper on the mobo panel was not placed right. i still have no idea why it only showed the error after i tried making a raid
