I've finally got around to overclocking my 660ti, I'm still pretty new at the whole overclocking thing so i was wondering if it would be a good or bad idea for me to revert to my default clock value when I'm not gaming. I'm thinking this would reduce the stress the gpu and the power consumption when it's virtually idle and the overclock isn't needed or if it's just a bad thing to do switching back and forth better overclocked and default clocked settings. Any other ideas would be appreciated as well
https://linustechtips.com/topic/7969-overclocking-and-reverting/
are you using afterburner or GPU tweak, if so, you can check your power consumption and it shouldn't be any higher at idle when you overclock it and the difference would be minor if any so it's not worth the trouble.
Reducing the stress on a gpu isn't a big deal either, (graphics card are made to be used all day for long gaming sessions and everything) it should last as long as you don't just crap on it with brutal processes all day everyday.
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/7969-overclocking-and-reverting/#findComment-89566
The GPU automatically downclocks when it is in not being used. Max clocks are only hit when the GPU is under heavy load.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/7969-overclocking-and-reverting/#findComment-89600
