Hiya! I currently have some random 5 1/4" bay reservoir/pump, and it's loud as fuck. The rest of my PC is relatively quiet--the fans whisper with the same volume as your lover as she leans over to sensually whisper into your ear to say that she's leaving you for someone else, and some of the components have fans that stay turned off even more than my gf--but this water pump is a monster truck in comparison. Does anyone know of a good, QUIET pump for a liquid cooling setup? Currently my loop includes 2 3x120mm rads, CPU, and VRM. I would like to add the GPU into the loop, and am not opposed to removing the VRM from the loop if it's too much water to push through. Any thoughts/suggestions would be helpful.
Also, does anyone know more about the waterblock featured at the end of this video?
Thank-you all!
-Sephiroth
https://linustechtips.com/topic/796898-quiet-watercooling-solutions/
On 6/21/2017 at 11:44 PM, LeapFrogMasterRace said:
Get a D5 pump from any company that has good reviews and I haven't seen the water block anywhere besides on the kit.
Thanks for the help! Where have you seen the kit for sale? I couldn't find it anywhere, and I'm planning on putting together a smaller PC for my brother with parts from my old one after I finish upgrading, and that cooler looked really neat.
Here is the link to the amazon page https://www.amazon.com/Swiftech-H240-X2-All-Liquid-Cooler/dp/B01AOF4KGK kinda pricey and the reviews aren't that good
Thanks for looking, but it seems like that block on it is the Apogee XL2, not the SKF, right? I thought it was neat, the one in the video, for having a .15mm fin distance, but if that's not the case I'll probably look around for something not 1/2 the cost of the rig. Thanks a bunch!
