Triple or double?
Go to solution Solved by AlwaysFSX,
Oh ok, I have no experience with 140mm fans so I didn't know if they were loud. But it makes sense more fans more noise.
Since they're larger they can move the same amount of air at a slower speed, therefore less noise.
I would get dual 140mm fans. Will move a little less air than three 120mm but will be quieter.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/79671-triple-or-double/#findComment-1092799
Dual 140, less noise overall and it still moves air
https://linustechtips.com/topic/79671-triple-or-double/#findComment-1092804
https://linustechtips.com/topic/79671-triple-or-double/#findComment-1092805
Got a buddy, (not on the forums yet, he's not big on joining communities online but I'm working on it) buying an air 540 on black friday, even if it doesn't go on sale, but wants to know if he should run three 120mm fans as intake or dual 140mm?
1. Cyber Monday?
2. What kind of fans will he be using, I would compare specs from a spec sheet on base my recommendation on that. I'm assuming we're talking bout air flow fans here? Will he be choosing from Noctuas lineup, or maybe Corsair?
https://linustechtips.com/topic/79671-triple-or-double/#findComment-1092930
