what RAM did you get? Do you have 2x2 sticks or 1x4 stick?
Also spec list would be helpful
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/79644-upgrading-ram-problem/#findComment-1092340
It was 4 sticks of ram and my specs are Amd phenom 8400, 500gb hard drive thats i know
have you tried using one stick at a time?
Hope I could help!
https://linustechtips.com/topic/79644-upgrading-ram-problem/#findComment-1092373
No
then i would try that
Hope I could help!
https://linustechtips.com/topic/79644-upgrading-ram-problem/#findComment-1092449
If you are running a 32 bit OS then your ram amount will read as 3 GB and change. You'll need a 64 bit OS install to see a full 4 GB and beyond.
My rig: 2600k(4.2 GHz) w/ Cooler Master hyper 212+, Gigabyte Z68-UD3H-B3, Powercolor 7870 xt(1100/1500) w/AIO mod,
8GB DDR3 1600, 120GB Kingston HyperX 3K SSD, 1TB Seagate, Antec earthwatts 430, NZXT H2
Verified max overclock, just for kicks: http://valid.canardpc.com/show_oc.php?id=2609399
https://linustechtips.com/topic/79644-upgrading-ram-problem/#findComment-1092465
