Hello to any X99 experts that might be out there! I'm building my first X99 PC for my boss as his replacement workstation. He needs a new PC by yesterday as his aging iMac is dying. Naturally I, the only PC builder in the office, didn't hesitate before offering to spec out and build him a replacement to the likeness of other existing PC workstations he has. After going through the build process in my head while buying the parts, it dawned on me that I'm not sure how to install the memory I purchased in the optimal configuration. The board is this: https://pcpartpicker.com/product/7q38TW/evga-motherboard-131hee095kr // User manual part 1: https://www.evga.com/support/manuals/files/131-HE-E095_Part1_v2.pdf // User manual part 2: https://www.evga.com/support/manuals/files/131-HE-E095_Part2.pdf
It has four slots, but I purchased only two DIMMs of RAM deliberately so he can upgrade to 64GB down the road should it ever become necessary. My question is this: what slots should be populated with the two sticks of RAM I bought to run in dual-channel mode properly? I can't find a straight answer anywhere, but my best guess after doing some digging is that you need to populate the odd slots first, which would be the outermost slots.
https://linustechtips.com/topic/796375-need-help-from-you-x99-experts/
I thought you just put it in 2 of the matching colour slots (or in this case, one in each couple of ram slots, just keep the side the same).
So on the left 2 slots, choose one side and put one stick in (e.g right) then on the right 2 slots put the ram stick in the right slot of those two.
Hope this helps!
Just joined the forum? Read this:
A Quick Guide To Get Started
Need Help Doing Something? Read this:
Guides & Tutorials Catalog
Need a New SSD? Read this:
Droidbot's SATA3 SSD Tier List
Need a New PSU? Read this:
PSU Tier List
In the mood for some memes? Look at these:
Linus Memes
Want to know my PC Specs and Peripherals?
CPU - Intel Xeon E5 2609 v3     Motherboard - ASRock X99 Extreme3      RAM - 16gb HyperX Fury DDR4      GPU - EVGA Nvidia GeForce GTX 770 SC
Case - Inwin 103       Storage - HyperX Savage 240gb SSD      PSU - 550W Enermax NAXN      Display(s) - 2x Lenovo L27i-28, Dell 24"      Cooling - Corsair H100i Platinum     Keyboard - Corsair K95 Platinum MX Speed      Mouse - Logitech G900      Sound - Audio Technica ATH-M50x     Operating System - Windows 10 Pro
Join the LTT F@H Team!
You can help scientists studying Alzheimer's, Huntington's, and many cancers by simply running a piece of software on your computer.
Start now: Folding@Home Install Guide and Links
what is he using it for? highly recommend ryzen just to save some money :)
you check in the manual to see, and populate those two preferred slots. usually its slot 2 and 4 (left to right)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
20 minutes ago, Muffinmanx2 said:
Oh, Pg 13 of the first manual has your answer
Did you even look at page 13? because the answer definitely isn't there lol
with this motherboard your chosen DIMM placements shouldn't matter. As a general rule of thumb, one should use the outside slots when available, but it probably won't really matter all that much if you don't on this particular motherboard**, and most motherboards/MC's in general nowadays are robust enough to deal with improperly configured memory just fine.
**Normally, there are 2 DIMM's slots per memory channel, resulting in 4 DIMM slots on a dual channel board and 8 slots on a quad channel board. RAM placement on a board like that can and is very important as placing your memory in the wrong slots can cause issues with channel configurations and RAM capacities/speeds and whatnot. A screw-up in that area will usually result in system instability (rather than not working outright) or a loss of performance (often a result of running with fewer memory channels than you should). Seeing as your motherboard is Quad Channel, and there is only 4 slots for memory, this means that each slot carries a single channel (rather than two slots carrying a channel together). As a result, there is no memory pairing or any real need to pay attention to channel configurations since any DIMM you install will be working on a separate memory channel compared to any others, and with how smart motherboards are nowadays there shouldn't be any issue to which channels are active and assigned tasks.
Unfortunately, Ryzen isn't widely accepted in the professional market as a viable alternative to Intel. I'm aware of the savings, but most businesses simply opt for peace of mind and go with what's been tested most between other, similar businesses. I didn't want to push such a new platform on him when he already has invested in other X99 systems and knows they work well.
2 hours ago, Muffinmanx2 said:
If he was running on an old iMac for this long, I doubt that he needs this much overkill. I agree with the Ryzen suggestion. Oh, Pg 13 of the first manual has your answer, and nobody needs 64 Gb of Ram for office work.
No they don't, but maybe in 5 years we'll want it. We're an architecture firm, so we need more resources for renderings and running several large programs at once. Ryzen is too consumer-oriented and we can't wait for Threadripper unfortunately.
Well manual says only to populate slot 1 first. The second stick can be placed anywhere else since this board only has 1 slot per channel.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
It shouldn't matter what RAM slots to use on a 4-slot quad channel board which would be why they have very little information on it, although I would use the outermost slots.
For a work system? It isn't stable enough IMO.
Ryzen crashes pretty hard without leaving crash dumps for diagnostic purposes, making it next to impossible to resolve issues.
While I am happy to use Ryzen at home, I still wouldn't get one for a work system yet.
You did not specify what kind of work this was for, so I assumed that it was just standard accounting.
That's what I've been hearing too. I really hope they crack the professional market with Threadripper.
Thanks for the clarification! That's the clearest answer anyone has given me.
1 hour ago, MuffinManDan said:
Well, you know what they say about assuming.
Lol, yeah. I was just trying to save your boss a little cash on a business rig. I see people build over the top PCs all of the time and only utilize it for programs like Quicken. I'm not here to sell you stuff, I would rather help my fellow forum posters save some money. I guess that makes me an ass :P
It's all good, I appreciate the suggestion. If nothing else it's great that there are other systems to suggest now that can compete with Intel.
So what processor is going in this? any GPU's? Ryzen is pretty beastly in the core count department, so it matches Intel's quality with quantity. AMD is my choice for content creation platforms. (I am still using the 2-year old Intel rig in my profile)
It has a 6800k and a GTX 1060. I just finished building it yesterday and I set it all up today. Should be a reliable workhorse for years to come.
Slots 1 and 3. Looks like memory always likes the odds and evens to be matched.
On 6/29/2017 at 11:51 AM, rockon5622 said:
Why not a xeon? ECC memory is nice.
It's nice, but investing in ECC has the best ROI when it's in a server configuration, not and end-user workstation. My boss is also in need of a new file server, so we'll probably go with Xeon or Threadripper for that, depending on how thst release goes.
