Nikon J1 lens problems
Solved by code_glitch,
Turn off AF (manual mode), switch from apeture or whatever your on to manual and you should be good to go. At least thats how it was on my V1 way back when, but IIRC the menus are all the same. Might need to set manual shutter too...
Jimkirk363 ·
Posted in Windows0 -
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory5 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
6
1
