CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($299.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Amazon)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($96.98 @ Newegg)
Memory: G.Skill - FORTIS 32GB (2 x 16GB) DDR4-2400 Memory  ($220.99 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($84.95 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($66.99 @ Amazon)
Video Card: PowerColor - Radeon R9 390 8GB PCS+ Video Card  ($344.49 @ Amazon)
Case: Deepcool - TESSERACT WH ATX Mid Tower Case  ($37.98 @ Newegg)
Power Supply: EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Amazon)
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($20.98 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($92.99 @ Amazon)
Software: AVG - AntiVirus 2016 (1 Year Subscription) - 3 PCs Software  ($43.61 @ Amazon)
Monitor: Acer - UM.WV6AA.B01 21.5" 1920x1080 60Hz Monitor  ($92.98 @ Newegg)
Keyboard: AmazonBasics - KU-0833 +MSU0939 Wired Standard Keyboard w/Optical Mouse  ($14.99 @ Amazon)
Total: $1522.90
Generated by PCPartPicker 2017-06-20 19:35 EDT-0400
so this is the PC im currently building, the purpose of it is primarily  going to be a learning PC for 3d animation. I have bought the CPU Cooler and Case so far, and the cooler i had bought when i was going to use a i7 and a appropriate motherboard, and PCPart builder does not say where I can buy the mount I now need and I'm curious where I can buy one. (the antivirus software, keyboard mouse, and monitor is just filler money for other parts ill need later). This is the first PC Ive built and I'm hoping it'll be able to preferably render stuff faster than my current laptops (https://www.amazon.com/gp/product/B017QDHENY/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1) at a wonderful rate of 24 frames made in 4 hours.
https://linustechtips.com/topic/796220-first-pc-build/
get a SSD it will help with boot times and responsiveness
 Main Desktop
CPU: Intel Core i7-14700KF
CPU Cooler: Arctic Liquid Freezer III A-RGB
MB: ASUS ROG STRIX Z790-F Gaming Wifi II
RAM: 32GB(2x16GB) Team T-FORCE Delta RGB 6000MHz DDR5
GPU: ASUS ROG STRIX RTX 4070ti 12GB
STORAGE: 2.048TB Kingston KC3000, 2TB Crucial T500, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Montech King 95 Pro
PSU: Be Quiet! Straight Power 12 1000W
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
https://au.pcpartpicker.com/user/johnno12/saved/4HDc4D
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
https://linustechtips.com/topic/796220-first-pc-build/#findComment-10023210
yeah ik, I forgot to add that into the build but the part I need help with is what mount do i need for the CPU Cooler, https://pcpartpicker.com/list/cNCHTH
The Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler may require a separately available mounting adapter to fit the MSI - B350 TOMAHAWK ATX AM4 Motherboard.
thats the part I need help with
https://linustechtips.com/topic/796220-first-pc-build/#findComment-10023229
Do not spend $93 on windows 10, go on ebay and purchase an OEM key for about $10. I have bought about 5 of these with no issues. Most times i get the key within 30 min. I will post a link.
Also maybe check out a GTX 1060 6gb card instead of the R9. It performs a bit better and is much cheaper.
http://www.ebay.com/itm/BAREBONE-PC-With-ORIGINAL-WINDOWS-10-HOME-32-64BIT-OEM-GENUINE-LICENSE-KEY-/182356559239?hash=item2a754c4587:g:F~MAAOSw2xRYT9RS
https://linustechtips.com/topic/796220-first-pc-build/#findComment-10024323
that isnt the part im worried about though, I'm worried about the CPU Cooler mount that PCPartPicker is saying I need. I've been able to find 0 results that have a site that works
https://linustechtips.com/topic/796220-first-pc-build/#findComment-10027693
I would just use the stock cooler. No reason to spend extra on a budget one.
I would also change the psu to the G2 or G3 or a Corsair RMx etc. A 550W is also more than enough.
https://linustechtips.com/topic/796220-first-pc-build/#findComment-10027707
2 minutes ago, lee32uk said:
I am but I enjoy the fact that I wont need a new power block encase I need to add nicety to it
ok, what should i do with the one i have now?
https://linustechtips.com/topic/796220-first-pc-build/#findComment-10027744
A 550W psu is enough for any single gpu system.
If you can return it without a surcharge then that is what I would do. If it is going to cost you $10 or more then you might as well keep it. As for the bracket you would need to request one from CoolerMaster if the retailer doesn't sell them.
https://linustechtips.com/topic/796220-first-pc-build/#findComment-10027776
