Considering the mobo is older than dirt, there could be several problems.  Is it clean?  Problems due to age can be enhanced if the mobo is dirty.  My next step would be to replace the CMOS battery.  Given the age of the mobo again, if the original battery is still on the mobo, then it's toast too.
How about the ram?  From the specs I found on the board, the mobo is only good for 1333 ECC ram.  What about the hard drive?  There is no SATA on the board so you must be using an old IDE drive.
Good Luck, you're going to need it.
https://linustechtips.com/topic/796152-help/#findComment-10022281
Only good with 1333 ECC ? What ? Have you checked the correct mobo ?
http://www.ecs.com.tw/ECSWebSite/Product/Product_SPEC.aspx?DetailID=810&CategoryID=1&DetailName=Feature&MenuID=24&LanID=0
I clean it. And removerd the cmos batery
https://linustechtips.com/topic/796152-help/#findComment-10022292
Sorry, my mistake.  I got my information here.
http://www.ecs.com.tw/ECSWebSite/Product/Product_SPEC.aspx?DetailID=827&CategoryID=1&DetailName=Feature&MenuID=24&LanID=0
MEMORY
  • Dual-channel DDR2 memory architecture
  • 2 x 240-pin DDR2 DIMM socket support up to 2 GB
  • Support DDR2 667/533/400 DDR2 SDRAM
https://linustechtips.com/topic/796152-help/#findComment-10022366
