Hello all.
My Cooler Master V1200 PSU makes a noise every now and then during use, and always during startup, the noise is 1 second duration, but is very disturbing, i removed the psu from the computer case and tested it in several positions, and it only makes this sound when its fan is facing down (as it mounts in the case), since the psu has fanless operation, i think that the sound may have something to do with the fan starting to run, i recorded the noise : https://www.youtube.com/watch?v=q2kQFlbgd0A&feature=youtu.be
do you think its normal?
thanks.
https://linustechtips.com/topic/795517-psu-noise/
Sounds like a bearing broke its not much but how long do you have on the warranty?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/795517-psu-noise/#findComment-10014695
4 minutes ago, YanDjin said:
I am from algeria, i dont think the warranty really stands here, anyway i entered the serial number on their website it says i still got warranty till 2020.
Contact Cooler Master support to find out if it's a common issue with an easy fix, if not, they'll likely be able to replace it under warranty.
https://linustechtips.com/topic/795517-psu-noise/#findComment-10014767
1 hour ago, YanDjin said:
I already submitted a ticket,but after a few days it says closed by system
Try to contact support via email?
https://linustechtips.com/topic/795517-psu-noise/#findComment-10015100
3 minutes ago, YanDjin said:
I can't find support email, I don't think they have one.
http://us.coolermaster.com/service/
Browse through that, see if you can find anything.
https://linustechtips.com/topic/795517-psu-noise/#findComment-10015243
thanks for the reply but i can't find anything about email, just phone numbers and Africa isn't even there.
have you listened to the sound record, do you think it is a bearing problem like billy_mays suggested in the first reply?
https://linustechtips.com/topic/795517-psu-noise/#findComment-10015291
Hmm, that's a bummer. Cooler Master is a large international company. I'd think they would have an email service or some form of write-in service.
I don't really know but you have a warranty on it still so it would be best to replace it regardless.
https://linustechtips.com/topic/795517-psu-noise/#findComment-10015320
