Okay. So I am pricing out GPUs for my first build. I will be running an R7 1700 on an x390 MOBO w/ 16G DDR4 @2400Mhz. My PSU will be bronze rated @ 600W.
It's a relatively modest setup, but I think it has a decent amount of room for upgradability in the future.
I only have a 60Hz monitor as of now (1280 x 768)
I have roughly $250-$300 left for a GPU. I see similar pricing on GPUs w/ 2-6Gb of physical memory, but all of them have different clock speeds. I'm pretty lost. It's a lot to take in and I want to make a good investment. I will be playing a lot of sandbox/open-world games as well as FPS, if that helps.
My question is: What is the relation between clock speed and physical memory, specifically? Should I go for the higher clock, or more physical memory?
Also, if you have any cards that you can suggest to me, it would be a great help.
Right now, I have my eye on this Zotac GTX 960 Amp Edition... Am I on the right track? Lol.
https://linustechtips.com/topic/795452-clock-speed-and-physical-memory/
I'd say go for a 1080p 60Hz or more IPS monitor first. Any further upgrade to the GPU won't be visible with a screen like that
Desktop benching:
