Hi guys
I might need your help. So I recently built this new ryzen p.c:
Ryzen5 1600x
Gigabyte AX370 Gaming K5
MSI GTX 1070
GSkill FlareX 16GB
Corsair 650W PSU
Corsair Crystal 460X case (non rgb version)
I was out of the loop (i used to build a lot of computers) now that I have set it up it works fine but the cpu temps are slighly higher imo.  As far as I know I did everything right. Ordered the AM4 bracket from corsair and bought a brand new H100iV2. At idle or little load it goes around 46-47 degrees and while gaming it touches 65 degrees. But I havent played any demanding games yet just some league and CSGO. I wonder if it goes higher.
The only thing I did not do was replace the thermal paste that comes pre applied. and also did not change the backplate on the mobo. But I believe you only do that for intel and replace it with the plastic one they send you in the box. Also the fans got really loud when I installed the corsair link software. I dont know whats up maybe you guys can help me out. The bios reads significantly less than HWMonitor does.
While we are at it, the ram blocks the radiator? I mounted it on top first but it doesnt fit. The ram isnt too high almost same size as a vengence or  a hyperX I really want to put it at the top and add two red led fans on the front.
Thanks in advance
https://linustechtips.com/topic/795353-reasonable-temps/
