I need help for my computer. I'm not sure what's wrong with it. I turn it on and windows starts loading and then it freezes. I reset my bios thinking that might help, but the same thing happens, except it says BIOS reset, press delete to enter setup. So I press delete and it freezes. I don't know what
the problem is. I'm thinking it could be the hard drive or possibly ram. If anyone knows what it could be, could you please comment.
Thanks
https://linustechtips.com/topic/7952-help-needed-for-computer/
If you have more than one stick of RAM, try taking one out at a time and booting up. Also try with different DIMMs in different slots. How did you reset the BIOS? Did you use the "reset to defaults" option, take out the CMOS battery or use the jumper on the board?
https://linustechtips.com/topic/7952-help-needed-for-computer/#findComment-89154
