Posted June 18, 2017 So I know Logitech recently came out with a new MX Master mouse (2s). Does anyone know if its worth buying the new one or getting the old one. Old version is 59.99 and new version is 99.99 on Amazon. Link to comment https://linustechtips.com/topic/794886-wireless-mouse/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 18, 2017 Hey. I have the MX Anywhere 2 mouse, but I'm inclined to buy the MX Anywhere 2S as well... Better battery life and higher DPI. Hmm... It'd be cool if I could upgrade to it instead of buying it. Link to comment https://linustechtips.com/topic/794886-wireless-mouse/#findComment-10007428 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 18, 2017 Unless you want flow functionality you can go with old mx master, im still rocking with one. The battery life is good enough, i only charged it every month or so before i go to bed. Also the new color choices is much better imo. 1 hour ago, Lucian Andries said: Hey. I have the MX Anywhere 2 mouse, but I'm inclined to buy the MX Anywhere 2S as well... Better battery life and higher DPI. Hmm... It'd be cool if I could upgrade to it instead of buying it. Do you need higher DPI? The battery life is already great. Magical Pineapples
