Posted June 17, 2017 Hey gang, Recently I've been debating on switching to water cooling. I've noticed recently that my GPU tends to run a bit hotter than I would like when it comes to gaming. Typically when playing something like GTAV it starts to hit temps of 80+, and when playing Space Engineers it hit nearly 93. I found that it was designed to handle up to 95, but I'd rather not run that hot. So I was hoping that maybe you guys could point me in the right direction with my set up, and with either option I have used the configurator in EKWB. My computer specs is as follows: Phanteks Enthoo Pro Intel i5-6600k Cooler Master Hyper 212 EVO MSI Z170A SLI Plus MSI Radeon R9 390 MSI Radeon R9 390 (crossfire) G.Skill Ripjaws V Series (4x8) Stock fans from Phanteks: 1x200mm front, 1x140mm rear EVGA SuperNOVA 850 B2 Now mind you, I've never water cooled a machine before. I figured branch out, and open up my horizons, and get a little help along the way. This loop is if I were to cool both GPU's https://www.ekwb.com/custom-loop-configurator/shared/oW5944d6230539c This loop is if I were to only cool the base GPU https://www.ekwb.com/custom-loop-configurator/shared/oW5944d644de451 Link to comment https://linustechtips.com/topic/794504-switching-to-water-cooling/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 17, 2017 Personally i would spend that money on better components, as i would only water cool when you have top of the line products. Magical Pineapples
