Powerstrip switch light flickering
Go to solution Solved by MrJoosh,
16 minutes ago, babadoctor said:
Is this a big issue?
I'm guessing you mean the indicator light on the power strip that your PC is plugged into, if so I doubt it - these lights are usually neon bulbs, and start to flicker over time.
I will only ever answer to the best of my ability - there is absolutely no promises that I will be correct. Or helpful. At all.
My toaster:
CPU: Intel Core i5-4670k @ 4.3GHz
Motherboard: Asus Maximus VI Formula
RAM: 16GB Corsair Vengeance DDR3
GPU: Nvidia GeForce GTX770 2GB
Case: Some free Sharkoon case
Storage: Crucial MX500 500GB SSD | Western Digital Blue 1TB
PSU: Corsair HX750
Display(s): Acer framless 24" 1080p thing | Acer 22" 1600x900 thing
Cooling: Corsair H100i AIO | 2 x Corsair LL120 front intakes on radiator | 1 x Corsair LL120 rear exhaust
Keyboard: Steelseries Apex
Mouse: R.A.T 7
Sound: HyperX Cloud II headset | Creative EAX 5.1 speakers
OS: Windows 10 Pro
