I bought a GTX 1060 3GB by MSI today and hooked it up to my PC. It worked perfectly and MSI Afterburner detected it and all game ran smooth at 60fps. I just factory reset my PC and MSI Afterburner says I'm running a Microsoft Basic Display Adaptor. I tried re-putting my GPU, installing the drivers (which told me it wasn't compatible with my version of Windows 10 64bit), tried updating Windows 10 and trying the drivers still no luck. Any suggestions?
https://linustechtips.com/topic/793554-gtx-1060-help/
delete drivers. Do a clean uninstall and download the correct ones from the nvidia driver website
https://linustechtips.com/topic/793554-gtx-1060-help/#findComment-9992979
did you DDU the previous drivers?
DDU to fully uninstall, then reinstall.
DDU  = a program called Display Driver Uninstaller.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/793554-gtx-1060-help/#findComment-9992981
Just now, Soctial said:
Its a full system factory reset, shouldn't the drivers all ready be deleted?
if you reinstalled windows, then yeah.
try it anyway, just in case the first install messed up or something.
Laptop:
https://linustechtips.com/topic/793554-gtx-1060-help/#findComment-9992991
Install GeForce Experience and let it auto update your drivers
Main Rig:-
Server:-
https://linustechtips.com/topic/793554-gtx-1060-help/#findComment-9993005
Already tried.
What happened?
Main Rig:-
Server:-
https://linustechtips.com/topic/793554-gtx-1060-help/#findComment-9993017
3 minutes ago, Soctial said:
Said this version of Windows is not compatible, even though I have the most up to date version of Windows 64bit.
download one of the older drivers from the nvidia website and try to install them, maybe it's just a bug in the latest version.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/793554-gtx-1060-help/#findComment-9993061
