Going to be building a PC this summer and i would like some advice on my parts, I wouldn't like to go above £1100 on all the parts and equipment.
I have all the parts in a notepad file and also have them layed out on pcpartpicker but without the keyboard because it wasnt on there.
https://uk.pcpartpicker.com/list/vxDkr7
PC.txt
CPU: Ryzen 3700X Motherboard: Gigabyte X570 Pro Wifi CPU Cooler: NZXT Kraken x62 Rev 2 RAM: 16GB Corsair Vengeance DDR4 3000Mhz GPU: Asus TUF OC RTX 3080 SSD: 250GB SK Hynix SATA and 2x 1TB Samsung 980 Pro M.2 PSU: Corsair SF750 Case: Cooler Master NR200 Monitor: LG 27GL850 Keyboard: Logitech G810 Orion Spectrum Mouse: Razer Viper Audio: Sennheiser PC37X and Logitech G560 Speakers
https://linustechtips.com/topic/793227-first-pc-build/
looks fine, make sure the mobo lists compatibility with that ram, if not change to ram the mobo supports for best performance, and upgrade to a 6gb 1060, the 3gb one is gimped in a few ways that make it much worse, or consider a rx 580 if you can find one in stock
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989595
First let's fix your bad graphics problem. Get a 6GB. Made a couple other money saving changes and upgraded the SSD to a 250GB.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£190.83 @ Ebuyer)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  (£97.80 @ Alza)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (£117.59 @ Aria PC)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  (£76.80 @ Amazon UK)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Aria PC)
Video Card: Palit - GeForce GTX 1060 6GB 6GB Dual Video Card  (£238.35 @ CCL Computers)
Case: NZXT - S340 (Black) ATX Mid Tower Case  (£62.10 @ CCL Computers)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£47.93 @ Ebuyer)
Monitor: LG - 24MP48HQ-P 23.8" 1920x1080 60Hz Monitor  (£93.94 @ Ebuyer)
Total: £963.33
Generated by PCPartPicker 2017-06-14 19:06 BST+0100
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989600
Should I get the palit gtx 1060 6gb or gigabyte rx 580 gaming 4gb?
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989625
Total: £963.33
https://uk.pcpartpicker.com/list/hqqPTH
How's that? I changed out the CPU because i would like t find a decent keyboard
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989635
https://uk.pcpartpicker.com/list/FxFbHN
Wrong link, it had no GPU
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989640
Dont skimp on key components for the sake of a good keyboard heres why (rough numbers)
You put in a £200 GPU and opt for a £100 keyboard cuz RGB and mechanical
6 months time the GPU is flagging, so you spend another £200+ on GPU
or
You buy a £300 GPU now that lasts 1 year + minimum and a £20 keyboard which you upgrade in a few months when you have cash
Its much easier to replace a £20 keyboard than a £150+ GPU cause you wanted RGB or mechanical
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989685
or
I could get a keyboard at Xmas, thank you, what card would you recommend then?
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989696
so taking the build you posted, minus keyboard, should be sweet, 1070 minimum:
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  (£87.95 @ Overclockers.co.uk)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  (£126.73 @ Amazon UK)
Storage: SanDisk - X400 128GB M.2-2280 Solid State Drive  (£46.09 @ Amazon UK)
Video Card: Palit - GeForce GTX 1070 8GB JetStream Video Card  (£369.98 @ Ebuyer)
Case: NZXT - S340 Elite (Black) ATX Mid Tower Case  (£83.93 @ Ebuyer)
Monitor: BenQ - GL2460HM 24.0" 1920x1080 60Hz Monitor  (£115.30 @ Amazon UK)
Total: £1106.73
Generated by PCPartPicker 2017-06-14 19:41 BST+0100
Note the 1070 GTX and the 340 Elite case
Ryzen Ram Guide
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989719
Total: £1106.73
Why the Elite case?
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989737
Why the Elite case?
tempered glass looks a TONNE better than acrylic and is more scratch resistant, look at some videos of 340 vanilla and 340 elite. I went from an acrylic side to tempered with my INWIN 303 and would never look back:
Ryzen Ram Guide
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989765
So I have a question sorta similar to this topic, so my "gaming" pc is about 6 years old now, and needs a major upgrade. It's still running on a amd athlon 270u and a cheap cooler. It sounds like a car engine when all the fans are going. It also still has a pair of XFX R7950 Ghost Editions in it. Should I just get a new cpu upgrade or save my money, cause as it is right now, I have only $2 towards it.
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9989866
Total: £1106.73
I cant seem to find any gtx 1070's that are in stock at around the £370 mark and i dont want to go higher, the only one i have found is the gigabyte gtx 1070 mini itx oc. Would I be able to use this with my setup or itx only? Or can you suggest a different gpu for me, thanks.
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9990245
Couple here
https://www.eclipsecomputers.com/Components/Graphics-Cards/NVIDIA-GTX1000/
https://www.cclonline.com/category/430/PC-Components/Graphics-Cards/NVIDIA-Chipset-Graphics-Cards/?utm_source=dropdown&utm_medium=dropdown-link&utm_campaign=pc-components/nvidia-graphics-cards
Ryzen Ram Guide
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9990568
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (£79.06 @ Amazon UK)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  (£50.99 @ Aria PC)
Video Card: Gigabyte - GeForce GTX 1070 8GB Mini ITX OC Video Card  (£334.91 @ Ebuyer) wait for stock to arrive.
Keyboard: SHARKOON - Skiller Wired Gaming Keyboard  (£9.99 @ Amazon UK)
Other: Acer GN246HLBbid 24 inch Wide FHD LED Gaming Monitor with 144 Hz, 1 ms, 350 nits, DVI, HDMI, Acer EcoDisplay  (£191.49 @ Amazon UK)
Other: Aerocool Aero-300 (£32.99)
Total: £1103.97
Generated by PCPartPicker 2017-06-15 03:26 BST+0100
https://linustechtips.com/topic/793227-first-pc-build/#findComment-9991813
