so im trying to get this one program from github: https://github.com/mohayonao/virtual-midi-matrix-pad
because I cant realy find any other program that does the same thing and i need it for a project.
it states that to install you need to run these comands:
$ git clone https://github.com/mohayonao/virtual-midi-matrix-pad.git
$ cd virtual-midi-matrix-pad
$ npm install
but the git command prompt doesnt recognize the npm install command.
does anyone know of any way to fix this?
https://linustechtips.com/topic/793069-need-help-with-github/
You need to install node.js
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
https://linustechtips.com/topic/793069-need-help-with-github/#findComment-9987798
17 minutes ago, IntMD said:
Not great with linux, but have you installed node.js & npm etc? Below has something on getting them installed in linux
http://blog.teamtreehouse.com/install-node-js-npm-linux
im on windows. look at the tag....
(its actualy easier on linux btw. since you can just use the native package thing)
https://linustechtips.com/topic/793069-need-help-with-github/#findComment-9987799
