Hey guys.
It's been a while since I posted here but I'm a little stumped with this build for work i'm doing. The build is a set of 3 5U racks built to tour and run a program called QLab which is a speciality program to run theatre shows. The problem i'm having is two of the racks have trashcan Macs in them, they were mounted to a rack shelf via heavy duty zip ties. But the zip ties broke on the tour it was just on. So what I need you guys's help for, is I need Ideas on how to mount the Macs on a shelf without breaking on tour. I would like to avoid one of those rack mac systems, for two reasons. 1. weight, this needs to be able to fly. 2. I don't have a huge budget for this and more just have to make do with what I have. I know this is a PC based forum so id like to put it out there that I can't build a rack mountable PC for this, because 1. budget 2. I need it to be super reliable.
https://linustechtips.com/topic/792997-touring-mac-pro-qlab-rig/
i'm confused how  you got the trash can macs into a rack did you take t the mother boards out and hang it flat?? though just use metal ties(stainless-steel-cable-ties) and a bunch of m3 double sided tape and some foam if it needs back support can't really suggest anything more specific since im not sure how its mounted in it
https://linustechtips.com/topic/792997-touring-mac-pro-qlab-rig/#findComment-9987137
it was just zip tied to the shelf no disassembly. The idea of M3 tape, foam and stainless steel ties is one i've had and thought about.
https://linustechtips.com/topic/792997-touring-mac-pro-qlab-rig/#findComment-9987155
