Hello, so i am building a Gaming PC but i have one problem, i want to buy the graphic card and CPU,RAM etc,from another country US
and i'm from another country (israel) so we have completely different power like "In Israel the power sockets are of type H. The standard voltage is 230 V and the standard frequency is 50 Hz." so i though to buy my power supply 650W from here and other stuffs from US the question is i will run the PC perfect or i will face problems?.
https://linustechtips.com/topic/792290-building-pc-need-help/
The PSU will output the proper voltages and such, so you should be good. It's not like they have Israel specific components, so you'll be fine.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/792290-building-pc-need-help/#findComment-9978612
Yeah, I think that should work. All the voltages of the internal components are standard globally, so I don't see how parts from another country wouldn't work. Also, lots of times devices have a little switch that changes the circuity from 120 to 240 volts. You might be able to find one of those from the US as well.
https://linustechtips.com/topic/792290-building-pc-need-help/#findComment-9978617
2 minutes ago, pommedeterror007 said:
US PSUs will be set to 110V as its the standard here. Most PSUs have a 110V/230-240V switch on the back near the power connector.
Just checked a few of my PSUs, I have both high end and pre built included PSUs, Some have switches that range from 100-115V / 220-240V or they dont have a switch you can activate but the unit itself will do 100V-240V on its own. Just consult the manual of the Unit you want to purchase.
https://linustechtips.com/topic/792290-building-pc-need-help/#findComment-9978635
